I have a 96 GSX-R750 that makes a flutter noise.
It may be the cam tensioner problem, but I don't think so. I'm not sure if I hear it all the time, or if its just on days I don't open the bike up. I usually only hear it when I'm between 4-5k (mostly because the exhaust is too damn loud, and it's that quiet)after the bike has warmed up. It's a quiet Fltftftftftftftft noice when I rev the engine with or without the clutch in.
I was reading in the old posts maybe a exhaust leak. I'll check for that tomorrow. I have a Micron Full exh. system (bought the bike used, with the exhaust).
I was just looking for initial reactions to this problem. thanks in advanced.
If it only does it when you accel and not decel, then I would look at the EX leak... If it does it durring decel, then I would look at the CCT
I went out today, Not a hard ride, but I got the revs up. No noise! maybe it's not properly lubricating the valves or something?
[ 04-04-2002, 05:36 PM: Message edited by: Cyron Green ]
One of the things with the auto CCT is that it will work sometimes, then others not work...
APE manual CCT is on order...
thanks Mr. The Freak.
[ 04-05-2002, 09:04 AM: Message edited by: Cyron Green ]
