K5 600.... I have led turn signals and the other day I believe a resistor for the signal completely burnt up and then one wire broke off of it causing my speedo and headlight to malfunction and not respond. I have a led fuse to stop hyper-blinking, so my question is this, Do I need to replace the resistor or will the LED fuse be enough and should I just connect the wires without the resistor?
Hand-Eye Coordinator
You need to buy a multimeter and start testing more than just the blinker. The info you have now is near worthless.
So the headlight and instrument panel aren't working except for neutral light. Apparently, from what I've read, there is a wire in the main harness that has a short or the connecters somehow got a short, haven't had time to check it but on my day off I'm going to give it the old college try.
So this is what was wrong with my bike. I don't know why this thing overheated and melted but thats what it was. I did exactly what the guy said to do in the video and it started working, only problem now is my speedometer is stuck on 0. will update soon!
About this Discussion
2 Participants
Bowsersgsxr600
Full Forum Listing
