That Side Winder give approx: 0 back pressure, I bet it sound good on the pipe. I agree with both previous post, its just lean. Maybe even back the mixture screws out in 1/8" increments to help get it started easier. The wheather in Florida is starting to cool off I bet? Also, when adding an ignition advancer, the bottom end can usually take a little more fuel the without, same for adding a Side Winder. That thing will require a main jet change from a good running set-up using a pipe with some sort of muffler. If you dyno it, you should see 2 very pronouced "dips" in the torque curve, I think in the 3,500-4,500 rpm range and the second in the 6,500 to 7,500 range. The ignition advancer may help that but be advised. Adding static timing will increase dynamic combustion chamber pressure and increase throttle response on the bottom end and midrange, however. That same pressure building will sometime cause the engine to actually loose torque up top because the piston must push up against the rising chamber pressure BEFORE top dead center. If you can, tune the bike on a dyno, two runs (it is cheaper that way). First, get the bike running the way you like it then take it to a dyno and run with the advancer and without.
