Hi,
I have been trying to repair my bike for a month, thanks to the aid of Jeff, could catch it. Now my problem is another one. Carb presents leaks gas.
I check everything but I don`t know what is wrong?
The bike start engine but after 5 minutes begin to leak by carb and turn off because is drowned by excesive gas in the cylinder.
The spark are new.
Today it change the float level and he was worse.
Continue leaks
Thanks Jeff and everybody for your Help.
i'd suspect the float valves. if they are sticking open, that would cause gas to overflow out the carbs and into the engine. pull the carbs off, and try spraying some carb cleaner through the float valves. if there's debris or gunk causing the float valves to stick open, spraying carb cleaner through them should clear it up. but if that doesn't help, the float valves will probably need to be replaced.
