I love this bike I put a yoshi slip on on the bike delete the cat set valve removed put a pcv on now it's throwing f1 code c33 double checked the wires it is all connected correctly but still throwing a code could it be a Volcker injector
I'd reconnect everything without the pc and see if it still throws injector code. If the injector code wasn't showing before the install I'd say it's a loose connection or something in the harness. It would seem odd it got a blockage out of nowhere at the same time you did your mods.
Did you get the bike custom tuned? What map are you running? Usually those codes show up when your injector duty cycle is too high.
About this Discussion
4 Participants
Anthony D
Full Forum Listing
