Hi guys I have a 2008 Gsxr 1000 and a few weeks ago it started knocking so I thought it would be the oil pump causing this as the oil is not reaching up and I installed a new oil pump and I still have the same issue, what should I do?
It's fairly easy to install a gauge to measure the oil pressure. It won't fix a failed bearing but at least you'll know. Other things that could fail include the pressure relief valve, the oil inlet strainer, and the pin associated with the gear that turns the pump. I think that there's at least one internal plug on the main oil gallery, though I don't see how it could come out.
