I need some advice please. 2008 GSX-R600 race bike. Annitori quickshifter and Two Brothers Racing Juice Box fuel module. Everything else is stock. Engine idles fine and revs freely on the stands in the garage when starting cold. Gets to operating temp, cooling fan comes on as normal. Does not overheat (98-100 degrees). Turn engine off. Wait 10 minutes, start engine again. Idles fine, then engine just stops. Troubleshooting the following so far:
No fault codes appear.
Engine will stall at idle or with throttle slightly open. Only seems to happen after engine runs through a heat cycle first. On track it will only happen on lap 2 or 3. Bike is a rocket until this happens. When the engine stalls I can hear the fuel pump spin up to build pressure again. I'm thinking it's losing fuel pressure and causing it to stall. But why?
Any tips or advice will be appreciated. State championship racing in 3 weeks so the clock is ticking!
Cheers, Pete
- disconnected quick shifter and ran as OEM (no fix)
- disconnected Two Brothers fuel module and ran as OEM (no fix)
- replaced fuel pump and filter in tank (no fix)
- Opened fuel tank filler while running in case venting blocked (no fix)
Cheers, Pete
