481 - 497 of 497 Posts
:hammer:banghead
I HAVE A k7 GIXXER 1000... BUT IT IS WAY MORE COMPLICATED TO MODIFY THROUGH ECU EDITOR THAN MY GEN II.
PARTIALLY BECAUSE I HAVE NOT FLASHED ANYTHING IN ABOUT 16 MONTHS.
WHEN I ENABLE THE 2 STEP, THEN IT WILL CUT TO THE RPM I SET ONLY WHEN CLUTCH IS ENGAGE AND AT FULL THROTTLE????
CORRECT????
IM WANTING TO RETARD THE TIMING AND PULL SOME FUEL IN FIRST GEAR SO I DO NOT WHEELIE OVER IN FIRST GEAR IF I USE THE 2 STEP AND IM HAND CLUTCHING???
CAN YOU DIRECT ME TO WHERE I CAN ACCESS A BIN FILE THAT SOMEONE HAS SHARED FOR A K7 1000
HELKP PLEASE
ADAM SPICER :cheers
What is so difficult using Ecueditor or Woolich Racing software on a K7-K8 1000? :scratch
Those Bin-files are not protected and you can modify them if want to make changes.
Bearded Viking Admin...
:hammer:banghead
CORRECT????
HELKP PLEASE
ADAM SPICER :cheers
I found the issue!
Your Caps Lock is stuck...
Hello everyone,
The software is available for download for free to check out, and you can build hardware yourself or I make pre-tested hardware that is plug and play, no wire splicing, you just have to insert 2 ecu pins into the ecu connector where empty spots are now, and same on the 8 pin black yosh connector.
ive gone through some of the posts but i am looking for the schematic/parts list to make this myself.
also what cables will i need besides
http://www.ebay.com.au/itm/111241824248?_trksid=p2060778.m1438.l2649&ssPageName=STRK:MEBIDX:IT
This is for a K8 gixxer 1000, and buying parts in Australia
TIA
Good news for GSX-R owners.
v5.0.9 of Woolich Racing Tuned (WRT) has been released
Postby WoolichRacing » Sat Jan 28, 2017 9:09 am
Added Disable Deceleration Fuel Cut for the following Suzuki Models
- 2008-2010 GSX-R 600
- 2011-2017 GSX-R 600
- 2008-2010 GSX-R 750
- 2011-2017 GSX-R 750
- 2007-2008 GSX-R 1000
- 2009-2011 GSX-R 1000
- 2012-2016 GSX-R 1000
- 2008-2017 GSX1300R Hayabusa
- 2007-2010 GSX1300BK B-King
I've been using a custom bin with fuel cut disabled for a few years and it's one of the best mods you can do to your bike.
Hi Guys!
I'm having lots of trouble trying to connect to a 21h50 ECU. I could reflash my K5 with my USB to Serial cable, but Im not able to connecto the this K7 ECU with Ecueditor.
I'm using a FT232 USB to Serial cable, with ECU on the bench, connecting like this:
FT232 RX-> ECU TX
FT232 TX-> ECU RX
FT232 GND -> ECU GND & power source GND
12V+- -> Ecu Power Source
I connect the ECU to the PC, then setup ECU editor COM port (below COM4) but when I try to read sensor data from Ecueditor it says: error: power is not on,ECU is in programming mode or Com port is not set correctly.Modemstat-6000....
I'm running out of ideas...anyone has experience on these ECUs?
Here are the parts I used to make a new flashing hardware after my Woolich LogBox's USB port failed.
+5V FTDI cable
https://www.ebay.co.uk/itm/USB-to-T...821423?hash=item467a13b06f:g:0dkAAOxygPtSrs53
I also made a new bike harness so I can use the original on bike and other for bench flashing.
SDS port connector (male)
https://www.aliexpress.com/item/6-P...291.html?spm=a2g0s.9042311.0.0.29fc4c4drrfpYz
Yoshi connector
https://www.aliexpress.com/item/Sam...342.html?spm=a2g0s.9042311.0.0.29fc4c4drrfpYz
Here are the instructions for FTDI wiring GSXR 1000 K9 Interface? - ECU hacking
If you want to use on bike harness you need to add few wires to ECU connector. Here are the instructions http://www.rbengineering.co.uk/media/Bike_Harness_Installation_Suzuki_Type_4_GSX-R.pdf
I haven't tried this with EcuEditor, but this works with Woolich software.
Bike harness' white Molex connector goes to Woolich LogBox
Same FTDI cable works with K5-K6 1000 and similar ECUs.
Hi! Thanks JK!
That was I was looking for back then, meanwhile we gave up reflashing that bike! Maybe I will test it in the future if any friend comes with his K8 to reflash. BTW, have some updates for you regarding the EMpro connection...email!
Thanks!
I flashed a Busa last night,and it has 2 issues... I'm posting this here because some people are already flashing the Busa bins into the K7 ECUs...
1) A mode stays on the screen all the time after the bike starts... And I can't change the modes at all.
2) Quickshifter is working only until 4th gear,it won't cut 4th--> 5th or 5th--> to 6th.
I have done:
1) Rev limiter to 12,000 rpm, gear limiters removed
2) Dragtools enabled,but slew rate retard is set to 0 ( is there a way to activate the quicklaunch without the slew rate? It's mostly bolt on mods on this Busa and it doesn't need it :dunno )
3) Quickshifter enabled,kill time set to 60ms and I'm using the sidestand switch of a K7 1000 for sensor with a custom bracket ( it has a diode in it).
4) Fuel map adjusted
I'm not sure about any of this but I know who could answer anything you ask. His name is Evan Steel at ESP performance in Tucson AZ. USA. I would say look him up and call him to pick his brain a little!
hi JK750, is still working free the ecu editor v2.5?
i have a 750k9 EU model..my old R6 with the TTL 5v ftdi cable works perfectly , (only writing)..now for my 750k9 EU i can read and write (with correction of cksm) on ecueditor v2.5?
^That has nothing to do with ECU flashing or with a K7/K8. Please post in the correct section.
Mods, can you move him?
+5V FTDI cable
USB to TTL Serial Cable FTDI (Genuine) chipset +5V Black 700461496663 | eBay
8.0US $ |6 Pin male female 6187 6561 6180 6771 auto taillight/rear lights plug,6Pin car taillight connector for Toyota,Honda etc.|Connectors| - AliExpress
Yoshi connector
6.0US $ |Sample,8 Pin 2.3mm male&female Auto connector for Furukawa,Auto waterproof connector for Toyata,VW,Honda,BMW etc.|connector lcd|connector batteryconnector adaptor - AliExpress
sorry for the wrong section. i ask to you if is possible have the pdf with the instruction for use bike harness to flashing the ecu
+5V FTDI cable
8.0US $ |6 Pin Male Female 6187-6561 6180-6771 Auto Taillight/rear Lights Plug,6pin Car Taillight Connector For Toyota,honda Etc. - Connectors - AliExpress
Yoshi connector
6.0US $ |Sample,8 Pin 2.3mm Male&female Auto Connector For Furukawa,auto Waterproof Connector For Toyata,vw,honda,bmw Etc. - Connectors - AliExpress
Hi, I'm sorry for digging this up but can you post the wiring diagram of the type 4 harness. I need it to connect my k9 750 to the woolich logbox. Thank you so much.
  • 2008-2010 GSX-R 600
  • 2011-2017 GSX-R 600
  • 2008-2010 GSX-R 750
  • 2011-2017 GSX-R 750
  • 2007-2008 GSX-R 1000
  • 2009-2011 GSX-R 1000
  • 2012-2016 GSX-R 1000
  • 2008-2017 GSX1300R Hayabusa
  • 2007-2010 GSX1300BK B-King
Can some one maybe disable the feulcut on my k7 1000 file it is a 32920-21H50 file im tuning it myself in winols but i cant seem to find the decel fuelcut map
