In my personal opinion your money would be better spend on a data logger and WRT box & software as it would give you all the control of what is happening to your bike rather than relying on some flashing by the unknown vendor. It would also be a lot cheaper. I would also stay away from any third party piggyback modules as the original ECU has everything you need (and WRT gives you access to it) for a track bike. The Bazzaz Z-Fi-TC is just a gimmick for the naive as far as the TC goes. If you really need one (again very debatable topic) I would go for Nemesis for example. Of course these are my personal opinions based on my experience and I am sure there will be those who disagree with it. You must also realise that the dyno will not give you optimal A/F ratios across the whole range because it is measured/adjusted in a very artificial conditions. Which is why again a log box and the day at the track is the best appoach. As to what will you notice riding do not expect too much past the hard changes like max RPM increase or disabling error codes. As you have disabled the steering damper (instead of just tuning the dampers map) some wobble that hopefully will not turn into a tank slapper is a real possibility. I am not sure what the "improved gas response" really means as it sounds like a marketing leaflet. It appears that you have done some engine work - head porting (?) but there is no details as to what compression you are have or how the flow rates changed with these bigger valves or whether the valve/ignition timing was adjusted accordingly. Looks to me like a lot of tuning is necessary yet to get this engine in order. Sorry for the length of it but there is a lot of stuff there to consider. So best of luck, let us know how did it all go and post some dyno results.
Shifu, Thanks for your feedback!
I agree with you on some points, but I do have a spending limit. Regarding the datalogging, I have been looking for an AIM EVO-4 with a dashboard. But ending up with just a AIM Solo DL which records some data from the ECU. (not possible to expand with analog port like e.g. suspension sensors).
I have the Bazzaz since it measures the A/F while riding and I have two different maps, selectable with a switch on the clipon.
(Tc on the Bazzaz is something you can forget). But all settings are adaptable with an USB port on the front side of the bike, no tools needed.
Nemesis is indeed a very good way to spend your money. Maybe later?? Any experience with Grip-one? Comparable?
I disabled e.g. the steering damper since I have replaced the OEM one with an Ohlins. Adjustable without just two fingers, no PC needed.
The company that did the flashing has done it before for the Dutch Ten Kate Racing Team. Guess they know what they are doing.
But this is no Honda ofcourse! :lol
The head was indeed flowed on a flow bank. The compression is now around 12.7:1 (was around 11.9, while the brochure promises 12.5)
The Ferrea valves are 1mm larger and stronger springs have been mounted. The flow with the treated ports increased 20%.
The Original cams haven't been timed. (Yoshimura cams are 1100euro!)
I hope the flashing takes care of some ignition timing.
The next track day will be end of March in Spain. I will post a dyno before that date.
Thanks.
