Very true, and its the next steps of getting a plug and wiring it up for a K7 1000 that i am finding hard to locate. Please don't hold back if i am blindWhy would you bother? You can buy a USB -> RS232 cable for about $7.
http://www.ebay.com/itm/111241824248?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thanks for the info about the plugs, yes the K7/K8 have two of the same plugs on the ECU.The K5/K6 ECM plugs had different key locations (and colors) and were not interchangeable. For K7/K8 one ECM plug is JAE MX34036SF1 (I think). Check your ECM as it may be used in both locations.
Most other connectors are available from Eastern Beaver, among others. The 8 position SAP connector (body/pins/seals) is available as Kawasaki part 26011-1773. The 6 position SDS connector body is Sumitomo 6187-6561. Pins & seals are separate.
Hope you know what you're doing.
The diagram shows only the yosh plug connection and what I can see I need the yosh and sds.
The difference reflects two approaches to the interface. The first juggles existing wires around on the connectors so that only the Yosh/SAP connector is needed for flashing. Nothing new is needed. I've never been a fan of this approach because of all the changes. The second, used by Greg Smith, adds two wires from the ECM to unused positions on the Yosh/SAP connector. This requires that both the Yosh/SAP and the dealer mode connectors be used for flashing. Additional pins for the new wires are needed. But in terms of modifications to the wiring, the second approach leaves the harness much closer to its original configuration.I think the answer is in post #1. Extra two wires in the ECM plug and they go to the Yosh connector.
