Hello everyone,
This is Greg Smith (smithabusa) from boostbysmith.com. I signed up as a vendor today. Petrik recently put up a post regarding ECU flashing potential for the K7/K8 GSXR1000's that up until now wasn't possible. The software is available for download for free to check out, and you can build hardware yourself or I make pre-tested hardware that is plug and play, no wire splicing, you just have to insert 2 ecu pins into the ecu connector where empty spots are now, and same on the 8 pin black yosh connector.
This was the post from petrik originally.
Happy 2011 new year for everyone ...
First trials with gixxer ecu proved to be somewhat succesful... for more info please see below...
Fuelmap tuning... including MS0/MS1 maps for e.g. nitrous use
Setting Limiters, removing top speed limiter
Ignition map tuning, different MS0/MS1 maps for e.g. nitrous or race fuel
Edit - Lets add that also enginedata is working with gixxers showing all error codes from memory or run time as well as ability to monitor all key sensors when dynoing the bike.
Install as for Hayabusa from http://www.ecueditor.com
