Ok so I've looked and looked... Can't find this information.. I need to know what the size and thread pitch of the screw for the gear shift linkage is. (The one for the actual aluminum shifter that connects to the spline) Mine disappeared today on my ride into work. I was able to at least put it back on and get into work, but now the search begins for the screw that is needed. Sadly this is my only mode of transportation as well.
Not the powers that be, not even close.
It's part number 01500-0625A but I can't find the size listed.
I'd ride to Home Depot, Lowes, or Fastenall they should have a bolt in stock that will work.
Yea, I ended up riding it home (30+ miles) and keeping an angle on my ankle to keep it in place. I don't have any hardware stores near where I work. There are some close to home, but I knew at home I have a selection of bolts.
Got home, cleaned up the linkage, the threads and all... Let it dry and then put in a new bolt with thread lock just to be safe. Stinks had to go all that way but hey... At least I found one that fit.
Thanks for your help though :) :cheers
