1 - 9 of 9 Posts
Hi all, I hope you can help me.
I have just bought a K7 750 track bike, I had it on track yesterday and I have a problem.
It takes quite a lot of effort to turn the bike and when i do it ‘falls’ so fast and turns so quick I often had to lift the bike up mid turn to reach the apex.
I hope you understand what I mean and can offer some advise to give it a more smooth turn in feel, I was struggling to get within 4/5 seconds of my usual lap times.
The front forks have Ktech internals and the rear shock has been worked on albeit for the previous owner who was about the same weight. The forks are level with the yokes.
I am running slicks with quite an aggressive profile but I’m not new to riding on slicks so I know it’s not just this.
Thanks
M
Thanks
M
You're supposed to introduce yourself first lol..but I'll try to help you out.
Those are sweet handling bikes so it's either a mechanical problem or improper set-up. or perhaps the bike is tweaked in some way (hope Not)
Have you ridden with this tire before? Maybe you need some time with them. What is the tire? What was the pressure ? Are they a used set ? Check for possible leaks... What is your level ?
Assuming the tires are matched and balanced properly....
If all OK, check the front end.
1) remove steering damper if you have one and check that it has good movement.
2) Raise the front wheel so the bars are free to turn. check that it turns freely with no play. If free play, adjust. if hard to turn, dissemble inspect steering stem bearings. Use torque wrench when re tightening
3) If all that OK. Loosen Triple clamp pinch bolts, axle pinch bolts and re tighten to factory spec using torque wrench.
these are very important: must not be over tightened. 16.5 ft lbs for all
4) check chain alignment/ check all motor mounts also.
Set-up>>
Sounds like suspension is upgraded
1) has it been serviced recently?
2) have you set it up? Sag etc.
If unsure of damping settings, start soft and work up.
provide a picture so we can get an idea of condition.
Set up your suspension.
Set-up>>
Thanks for the advice, I bought the bike and brought straight onto track without getting to check it over. I’ll get the front end stripped, checked and torqued up and see how that goes..maybe there will be something obvious.
I know I need to set up the suspension to suit me, and I can usually sort out the easy stuff myself with a bit of tweaking on preload, comp and rebound..I was think more about the geometry being out? I’ve read Gixxer’s of this age respond well to being lifted up front and rear?
Regarding introducing myself, my name is Mark..I’m 45 years old and fast as fast fuck :banana seriously, I’ve been riding bikes since I was 8 years old..racing up until I was 30ish and track daying up until about 5 years ago. I would consider myself fairly experienced and fast compared to the average Joe but slow as a snail compared to Mark Marquez..top end of fast group on track.
I’m writing this from work but when I get home and into the garage I’ll find out more, I think if memory serves me right they are Metzler racetec slicks on 180x60 on rear but I’ll confirm.
I’ll see can I get a few pics up later too
Thanks again and help is greatly appreciated :smile:
PS I think I’ve attached a picture of me at Portimao track last October..styles a bit old school but I’m too old and stiff for the latest head down stuff :crying:
Discussion Starter #6
Maybe a two post wonder?
I think I have it sussed, the front forks just had a service. They are ktech 20mm cartridge kit..preload has 18mm of adjustment and they had been set at just 2mm
I’ve adjusted it to a more appropriate level of sag and ‘feel’ on the old bounce on the forks method. By contrast the rear was very hard..so I assume with the setup the front was compressing and staying compressed too long, hence stepening the steering angle forcing the bike to turn too much.
I have her much more balanced now, I’ll know if I have her sorted next time I’m out.
M
M
Splendid !
Was there some specific reason you did not attempt to make improvements at the track ?
You should still still check all the other stuff mentioned above.
Thx for avoiding OPW status lol.
g
Discussion Starter #8
Splendid !
g
Yes buddy that is the question..why the heck I didn’t give the bike a better inspection on the track day..tbh I think I was just so excited to finally get back on track with my buddies I just wanted as much bike time between the showers we had.
Anyway, I’m back out again on the 3rd August so I’ll let you know how I get on :wink2::laugh:
1 - 9 of 9 Posts
