Hope someone here can help me out with this one, Does anyone know which wires going to the clocks are acutally needed to get the LCD Display & Tacho working??
My guess is all which is needed are:
Live
Ground
Tacho
ECU bus (Info for display)
Is this correct, and get anyone help me identify which are the colours??
The K5 wiring diagram is available in color on scribd. Should be close enough for your purposes.
What about the speed sensor leads? Seems a bit suicidal to not have the oil pressure indicator light connected.
Sorry BillV, what is scribd?
To give you some more background, I have to K6 engines in the back of a mini, I am tyring to use one dash with change over switch and external lights for oil and neutral. The speed sensor I'm not using.
so Far I've worked out
Blue/Black - Neutral light
Blue/Yellow - Hi Beam Light
Lightgreen - turn indicator right
Black - turn indicator left
Green/Yellow - Oil Light
Pink - wheel Speed
Black/Red - wheel Speed
Black/light Green - Fuel Level
Red/Blue - LCD Back Light??
Orange/Green - Ignition live
Black/white - Ground
My guess is one of this is the Engine RPM and the other sends digital info to the dash??
Yellow/Blue - ???
Black/Green - ???
Can anyone help me fill in the blanks, and tell me if any of the above is wrong?
Thanks
Jim
Here's a few but it's in the diagram:
R/Bl always 12V (keeps the clock ticking?)
Y/Bl tach
B/G serial data
Or/G switched 12V (maybe it's the backlight and other things that shut off)
B/W ground (note that sensors on the bike have their own signal ground system B/Br)
B/R power to speed sensor? (believe it's a Hall effect sensor)
P speed sensor output signal
B/Y high beam (not Bl/Y)
BenS's link will get you there but it's faster to use http://www.scribd.com/doc/11804325/GSXR1000-2005-K5-Wiring-Diagram.
Should be an exciting mini.
About this Discussion
3 Participants
Jimster
Full Forum Listing
