The instrument cluster on my k6 750 is working only spasmodically. It seems to work OK for a while after the battery is disconnected and then reconnected, then dies overnight. Almost like a boot up problem. The red backlight is working but no LCD. Is the cluster broken or is there another fix? Thanks in advance.
Hand-Eye Coordinator
What is your battery voltage in the morning? What is the general condition of the machine/wiring? Post pics.
Thanks for replying MacBayne. Condition of bike is generally good. Twenty odd thousand miles. Wiring is standard apart from the reg/rec which was moved away from the heat of the original position. The connector behind the clocks is very good. The big connector under the fairing on the left is dirty but looks OK. The issue is repeatable/ predictable. Clocks dead, disconnect battery and wait half an hour, connect, clocks working again. Works for a few hours. Dies until disconnected from battery and reconnected, repeat ad nauseum. Sorry cannot give voltage readings.
