1 - 2 of 2 Posts
Need some help. Went to put fuel in my bike and after filling up bike would not start. Swapped out my fuel pump and rectifier. Still nothing. Showing code -C00. Does that mean I have no codes showing up. Do I try changing the plugs? Fuel pump primes. Starter works just wont start.
Are you using a dealer mode switch or something jury-rigged? Any codes would go away if you shut the ignition off and turned it back on.
Are you sure that you put suitable fuel in it? Years ago someone inadvertently put an energy drink in the tank.
Check the fuses. Did you move the tip-over sensor?
1 - 2 of 2 Posts
