I was out ridding on the weekend and mid trip a coolant hose on my water pump let go. I trailered it home and the coolant that was hitting the ground mostly looked fairly clean/green. After removing the coolant hoses around the pump and dropping the last little bit of coolant out, I noticed the coolant color was off and looked like it had mixed with oil. (Pic attached). I just changed the oil befor my ride and did not notice any coolant in my oil. No coolant is notiicable trough the oil sight glass either.
My question's are.
Can oil/coolant mixture go one way? Or does the oil first conteminate the coolant?
Is the likely cause of this failed seals in the water pump?
Sorry for the long wrIte up. Any help appreciated. Cheers!
Fucked a good ride.
Oil separates from water, no separation present, replace the hose you removed that had a crack in it, fill it with coolant, bleed and let's finish the ride.
I don't claim to understand what happened but wonder if more is at play than you realize. The boiling point of 50/50 antifreeze is around 225 °F. Our bikes operate at significantly lower temperatures, so the pressure on the hoses should be minimal. There will be some pressure buildup due to thermal expansion as the bike warms up but essentially nothing beyond that. So it sounds like a hose "letting go" is associated with a clamp that was never tightened or a rotting hose. Or were you somehow operating at higher temps? Next, the pump actually has two seals, one for oil and one for coolant, with a drain hole to the outside between them. A failing seal will result in coolant or oil appearing on the pump or crankcase near to the hole. Oil in the coolant or vice versa is generally associated with a failing head gasket or frost plug. Neither is good. Probably not what you wanted to hear.
It was a "rotting" hose for sure.
It was split just above the lip of the pump, immediately above the clamp, very hard to take the hose off the pump because it was stuck to it.
We replaced the hose tonight, it was the back one behind the cog cover.
Pump looks good, gave the system a good flush, will finish bleeding it tomorrow.
I doubt that will be giving him too much more trouble.
750 kilometre trailer ride home, 1500K round trip for his Mrs
I have 2006 gsxr, I have had 4 oem gaskets put on, I’ve noticed it is leaking from exact same spot everytime. The last time I put on a gasket, I noticed by a screw hole there was some scarring on the metal and by the screw hole! Would this cause the leak? I contemplated putting a very thin layer...
I just replaced my oil pan and oil strainer('07 600). The strainer basically just slides into the opening and there is grooved stay. The rubber strainer didn't seem particularly firm in place, with a good O ring washer also installed. Does the pan offer any support once installed. Thanks a bunch!
Sorry for another oil post.....
I just did an oil change on my track only K8 and have filled with full synthetic but not started the bike yet as I'm a fraction short.
I've just had 4L of Castrol Power1 delivered and it's Semi-syn. 1st thought was to send back but after a bit of Google it looks...
Dear Mates, hope you are fine, I was hoping to get some advice regarding which engine oil I should use on my Suzuki Gixxer 155? I've 5000+ kms running and previously used Shell Advance Ultra 10w40 Full Synthetic. Hoping to get your expert solutions fast.
Thanks in advance. :woot
**In addition...
just cut one open and not impresses with the internals, looks to be the same construction as the old frams :piss which were pure crap, paper end caps that can come loose. Also made in china, been using Hi-flow for the past 20+ years and will defiantly be staying with those.
