Please help! Injectors aren’t spraying. My fuel pump is cutting on, it’s not my battery, not the kickstand switch! All I did was changed my quick shifter to gp and changed my battery to a lighter battery. Wouldn’t start. I replaced my battery and put the old one back in which was perfectly fine and hooked everything back up. I now took the tank off, cleaned it all completely out and checked my fuel pump. Also bought new spark plugs just Incase it was them. It is turning over but not firing.
Hand-Eye Coordinator
How do you know that your injectors aren't spraying?
Are you sure that the battery leads are on tight? (And on the right pole)
Measure the battery voltage while cranking. It wouldn't hurt to also measure the voltage at the O/W lead on the dealer mode connector while cranking.
fuel pump,pressure regulator, make sure no lines are clogged, food and or return.. then check with MM for signal as well.. go from there, FI code(s)?
