K5 stock exhaust vs Suzuki Yoshimura Tri Oval
6949 Views 7 Replies 6 Participants Last post by  BillV
Just wanted to know if anyone has information about K5 stock exhaust compared to Suzuki Yoshimura Tri Oval slip on. I want to know what is the difference performance wise, power gain/loss, fuel efficiency if affected, would I need to refuel going from stock to yoshi. Any input much appreciated. :smile:
1 - 8 of 8 Posts
It will be different from bike to bike, depending upon location, altitude, dyno and other factors. I'd would install that slip on and go from there. Some bikes benefit from a remap after a slip on and many won't likely need it. I personally was not able to get away with NOT retuning my bike after I installed a slip on and air filter so I had to pick up a PC5 and take a trip to the dynoman. Very glad I did. You many have different results. In any event, that is a great looking exhaust. :thumbup
You're probably not going to gain any power at all, it'll be more for the sound.
That looks like the 99000-79N12-021 catalyzed muffler. I can't tell from your pic but the label normally has "Catalyzed" between "SUZUKI" and "Tri-Oval". Other features are a permanently attached/welded on midpipe, an integral exhaust control valve, and a small water drain hole at the bottom of the front cap. The muffler was apparently included on the CRU models that were only sold in the UK in 2006, hence the catalyst which I think kept them Euro 3 compliant. They used the standard E2/E19 ECM. The muffler was well thought of but expensive. Claimed 6% more torque at low RPMs, probably due to the control valve. Search here for the PN and you'll find a bit more info/pics.
I don't recall ever seeing that muffler on a Yoshimura site, i.e. it may only have been available through Suzuki.
Hmm, never knew that. It also looks shorter to me than the regular tri oval of that time. Unless a previous owner cut it??
That looks really nice and a little bit old school. Try it out!!
It's not cut, which would probably be complicated with a catalyst inside. Definitely old school but still attractive. Beauty's in the eye of the beholder but I'm inclined to say that it looks slightly better than the TRC. I first found it in a K5 Suzuki accessories catalog. I suspect that its price kept it from being better known. Here it is installed:
http://oi64.tinypic.com/343g9de.jpg
It first came out as 99000-79N12-007 but I don't know what the difference is.
There's a K6 "Phantom Limited Edition" idling
It looks like a garden variety CRT model with this muffler so I don't know what's so special. He claims that the light grey is lighter and has more metallic but I don't see it. The rarer model is the CRU.
  • Like
Reactions: 1
I've snooped around and found that the 99000-79N12-007 had no catalyst and apparently was only sold in 2005 before being replaced by the catalysed 99000-79N12-021. They are visually very similar, so much so that Suzuki continued to use pictures of the 007 in catalogs listing the 021. Here's a picture of the 007:
http://oi44.tinypic.com/motjd.jpg
If you compare the label with that in the above #7 link, you'll see several differences in the text as well as the label's placement on the muffler shell. Based on that, I now believe that the OP's muffler is the 007.
The change appears to have been driven by the evolving European emissions regulations back then.
1 - 8 of 8 Posts
