People who have K5-K8 1000 Galespeed wheels and Brembo calipers, have you had problems with brake disc spacing?
My friend had the same problem with Brembo HPK calipers and Galespeed wheel with his K5 1000 as I have now with K9 1000 front end, Brembo M4 and Galespeed wheel (K5-K8).
Right side brake disc is aligned pretty good but the left side too much to the left and almost touches the caliper. This is not a problem with stock calipers because the stock calipers have wider gap between the sides.
It's not a problem to fix this. Just need to machine down the wheel hub's brake disc contact area on the left side.
Hey Guys, i’m new here. i joined to ask a question, i got a used 05 1000 clean title (18k miles) about 3 months ago, it’s cammed, and has a new crank and rod bearings because the previous owner spun a bearing, and rebuilt it himself. He gave me the old crank and bearing for proof. It’s been...
Hi I've just purchased a gsxr 1100 L and the steering damper leaks, i want to keep it standard, does anyone have one for sale, or knows of someone who car repair it ?
thanks
Shaun
I want to gear my 07 GSXR 1000 but i don't want to gear so much that everytime i get on the gas the front end comes up on me but i would like a little more acc.. So Should just go -1 or should gear it more than that?
