1 - 10 of 10 Posts
Anyone else getting a chirping noise from the front brakes while braking from high speeds. I went for a nasty canyon ride that tested my brakes well, and they seem to make some noise now. Just wondering if anyone else is experiencing this?
Sounds like glazed brake pads. You'd need to remove them from the calipers and have them abraded with sand-paper. Some good mechanics smear a light coating of copper or some other high-temp grease on the back of the brake pads (facing the pistons) to reduce the possibility of brake squeal. Just a light coating, mind you. Too much and the pistons will get gummed up.
Any suggestions on the grit of the sand paper, shouldnt be a problem to do it your self at home right?
Mine doesn't do that but does seem to wag from side to side a little when braking hard from higher speeds...(170 plus)
That's called a weave, sorta like headshake but it's comming from your rear end. I suggest you drag the rear brake during heavy front braking.
Discussion Starter · #6 ·
Anyone?
Anyone?
I believe medium to fine grit will do the job.
BTW I have had 3 bikes delivered to me in the crate the past 3 years. I always clean the discs with brake/contact cleaner before even rolling the bike a meter. There is always a thin layer of protective film on there that needs to be removed. I would suspect some dealers miss this.
I also try to bed in the pads carefully gradually increasing braking the first few miles.
comeback - great suggestions on a topic that needs to be addressed more during break it - THE BRAKES!
you're right on the money - and an asset to this board
Discussion Starter · #9 ·
I took it real easy on my breaks for the first 100 miles or so, your def right about breaking them in as well.
Sorry, Chevelle. Was off the board for awhile, due to a weekend trip to the track. Nice to see that there are lots of others here (thanks, Comeback!) to help you.
1 - 10 of 10 Posts
