I need a bit of help . I'm trying to set the bike up for a trackday and have no manuyal yet. I ordered one but it is not here yet. I'm just looking to change out the coolant at this time but I am noit sure where the drain plug is or the exact procedure. It shouldn't be too hard but I'd like to know whatq I'm doing before I start tearing into it. by the way there are two drain plugs on the motor on either side of the cases on the sides at the bottom. What are those? I opened one it wasn'tt orqued much and there is oil behind it. Thanks for any help i'll be changing tires so will be in and out but any help[ is appreciated
Yeah, what he said. Then fill with water and let run and get up to temp, drain again and refill with water and you're good to go.
I don't even think they have a "drain plug" you just disconnect the hose and let drain that way.
