recently bought a gsx k5 600, the bike so far has changed the spark plugs and fuel pump.
When the bike is hot (103-106ºC is summer here) after more or less 1 hour, from one moment to another it starts to jerk, trying to turn off, being impossible to drive.
At the moment it turns off, "Check" appears and the fuel pump does not start or make a sound until it drops a few degrees, and if you go slowly through the city again it turns off again showing check again and so on until it cools down or take the highway or a route with less heat. (I doubt that it is a temperature problem because if it is hot at the beginning it has no problems)
I really need help because I don't know what else to check
the stator is correct
Replaced fuel pump
The kickstand bypassed
and the emergency stop button too
Thanks a lot
Replaced fuel pump
Thanks a lot
