· Dreaming of buttsecks for years...
The system should pressurize as it heats up. It's common for a something to happen at the cap which prevents this. Does it boil and spill from the expansion tank?
It does start to boil but I’m not getting no pressure to any of the hoses on the radiator
What you you mean you're not getting any pressure? The system runs at 12psi, which won't feel like much if you're just squeezing the hoses. The system must have pressure to work properly. Take the radiator cap to a local radiator shop and ask them to test it. While you have it off, clean the neck of the radiator really well and check it to make sure it's flat.
