I have seen mine and many other K4s with an oil seep on the left side. Is it the oil pan or some sort of lip seal higher up? Looks to be dripping down from the water pump area. Is definitely oil, not coolant.
Anyone know for sure? Thanks
Not the powers that be, not even close.
either the clutch pushrod seal or the trans output shaft seal. if you take the front sprocket cover off you can see which one it is.
He Who Touches Himself
either way, you gotta split the cases to replace them....
