Is this a fact or a mere excuse
  • Whats the truth in this matter
    Votes: 0 0.0%
  • Should i go to another shop ?
    Votes: 0 0.0%
  • Total voters
    0
1 - 2 of 2 Posts
I ride a K4 1000 and recently fitted some mods. One of them was a powercommander and on the weekend i had problems. The engine just cut out on me when i was doing about 160 in 6th. I gat it going again for it only to die about 3 kls down the road. Then it would not start so i let it sit for about 15 minutes. I got i started and it did it agian . Fourth time lucky it was fine i rode all afternoon no problems road in 6th to about 260 and had no problem.
Today i rang the bike shop and they seemed puzzled and the told me that they have heard of this problem happening to another customers bike. They believe its not a mapping problem but a hardware fault
Has abyone had this problem ?? What should i do??
you should post this on the 1k forum. It could be a map issue because if it happens to you all the time on 6th, then there must be something programmed wrong.
i mean, i don't think there is a problem stock wise but once you add the pc on, it happens like that... then the target will be the pc
1 - 2 of 2 Posts
