Hey everybody I just picked up a k4 gsxr 1000 limited edition black. I got the bike on a good deal because when I picked it up it would idle great but wouldn't rev past 3000 rpm, still shifted through every gear fine and was rideable. Figured I could clean the fuel pump or adjust stva and it should solve the issue. The owner said that the tank was rusted before but he had it cleaned.
Had my dad try to ride it home but had to stop because it would only go about 50 mph and sounded horrible forcing it down the road with me in a car behind. After about 30 minutes of that we got AAA to tow it the rest of the way.
When we got back to the house the bike wouldn’t hold its idle. it starts up great to 1200 rpm then slowly drops rpm until it shuts off. Also if you touch the throttle it will shut off. Hitting ignition and holding the throttle will keep the bike on. I cleaned the fuel screen and did the internal filter bypass on the fuel pump after doing a flow test which solved the issue of not being able to rev past 3000 it can now rev to limiter but won’t idle and won’t rev at all unless done right when the bike starts which makes it practically unrideable. Stva is good butterflies are moving correctly but I still removed them. No FI lights or codes in dealer mode. Does anyone have any suggestions? Worried that the abuse on the highway did something.
