I have a Silver K3 that is the best bike I have ever owned. However, I have somewhat of a minor quandary about my 1000. For some reason I can't to figure out, I keep striping the lower fairing bolt on the left side (the small fairing bolt nearest to the kickstand). I am not a "heavy hand" kind of guy, but I have striped 2 bolts so far. It is always in the same spot. Is anyone else having this problem? Are there any other stronger bolt options out there?
I know these are probably really stupid questions, but I have to ask. I am really careful each time (obviously not careful enough), but I seem to keep striping the same bolt. I bought a few extras the first time I striped it just in case, but thought I would query GDC to see if anyone else had this problem and if anyone else found a solution. Anyone? Help a brotha out
did you strip the threads or the hole where you put the hex head?
you probably have bad tools. hex head bolts are very sensitive to different tolerances, so i would suggest getting some snap-on hex head wrenches.
