1 - 18 of 18 Posts
Just had RaceTech .95\'s & stuff installed...And
How many mm of tube showing is a good starting point...?
I took a rr measurement and I have 334mm eye to eye includung the traxxion shim kit (All 3 shims installed)...
If ya can help me out give me a call cause I'm working on the bike...240-417-7002
Thanks
Here is your "R"
Re: Just had RaceTech .95\'s & stuff installed...And
My 750 is 340mm (6mm spacers on stock shock) and 7mm of showing forks.
ild say 4mm of "tube" not including the cap
what model bike are you dealing with?
Discussion Starter · #6 ·
o1 gixxer 600...
One more thing...The max (Rider Sag) I can get out of the thing is like 18mm (Front)...rear is good to go...
18 mm sag in front? wow, that thing is stiff. i assume thats with the compression set at nil -
oh well just make good notes and RIDE THE THING!!
95's is a tad stiff...why did you go with that you are nothing but 160 soaking wet carring two bricks...
Thanks
pm'd ya....
o1 gixxer 600...
I think you have some internal issues with only 18mm of rider sag. (Stiction, oil level, shim stack....etc)
Discussion Starter · #11 ·
and 2 bushels of oranges...
seriously I'm 185...without gear...
then the .95 would worl . .925 would have been better.,
sounds like sticktion to me also
i ran 340 mm eye to eye., and 7 mm of fork showing including the cap .,
what front and rear sag numbers did you have with that set-up?
25-30mm fornt and rear i was 190lbs then....
that was with a 425lbs spring on the rear...
That is what I thought...You have the rear jacked up about 6mm more than me but you have about 10mm less front sag. That is just two different way to get the same geometry.
GMD set mine up with about 334mm eye to eye, 4-5mm of forks above the triples (sorry don't have the exact numbers with me).
As for sag numbers GMD recommendeds 38-42 mm rider sag front and 7-10 mm free sag rear.
Assuming you don't have a stiction problem, you could always cut the spacers down some to get the sag you're looking for. Maybe you didn't cut them down enough in the first place?
And it looks like I'm not the only person who thinks you should have gone with softer springs, eh?
Discussion Starter · #18 ·
According to the race tech chart for my weight I needed a .938 weight spring... which is closer to .95 than .90...
It's not overly stiff...Holding the brake and pushing on it to simulate a reasonable bump or hard stop my zip tie shows that I used 3/4 of the allowed travel...
I'm going to call the shop tomorrow cause they are closed today...
1 - 18 of 18 Posts
