My 2007 gsxr750 got stolen it got recovered and now I have a hole in the stator cover..and missing the starter idle gear .looking for parts and if any one could share a diagram or something
Yes they wrecked the bike..and it was found like this with out the gears..I took the stator cover off didn’t see no metal shavings inside it..or the washers for the gear..I’m hoping the motor still good.. but won’t know till I replace it and try to start itThe Geek got in while I was composing so this duplicates some of what he said.
There are diagrams in the parts fiche that the online sellers all use like this. See the crankcase cover or starter clutch sections. But you really ought to download a service manual if you're going to work on the bike. Note that failed starter idle gears can be associated with the crankcase breaking where the shaft for the idle gear is supported. Not good. You'll just have to check.
It looks like idle gear cover broke instead of the stator cover. Is more broke than I see? Did the thief drop the bike?
Do you know if you can push start your bike with out a starter idle gear?The parts fiche is pretty good for both the exploded diagram, identifying part numbers, and purchasing. But you'll also need a service manual for doing the work.
Thank youYup. I've done this intentionally before to eliminate the starter gear/clutch as the source of a strange sound.
I just tryed push starting the bike today...Yup. I've done this intentionally before to eliminate the starter gear/clutch as the source of a strange sound.
Okay thank youThere's a bit of drag even with the clutch pulled in. A hill helps a lot.
What’s the worse thing that cold happen if one of the starter idle washers fell in the motor and ran with it in there?..jw cause I think that’s what happens to mine when it was stolenThere's a bit of drag even with the clutch pulled in. A hill helps a lot.
