1 - 15 of 15 Posts
AS OF JAN 2, 2003 THE 1127/1216 MOTOR HAS BEEN SOLD!!!!
HAPPY NEW YEAR!!!!!
STILL HAVE THE 1988 750 and the BIKE & stock 1127 MOTOR PACKAGE available and will be changing the price on it in ASAP!!!!!
JDB1371
[ 01-02-2003, 09:15 AM: Message edited by: J.D. ]
Ampdog,
That would be the HOOKUP!!!!!
And this motor would fit right in...
Got a Dyna 2000 to go with it too, IF NEEDED, NEW OR USED.... GOOD PRICE AS WELL....
JDB1371
[ 01-06-2003, 06:47 AM: Message edited by: J.D. ]
Could one of you guys gimme the category at Dragbike that the...chassis I'll presume is located in? I can't open the link via any method.
Thanks in advance,
Todd
Discussion Starter · #6 ·
FELLAS,
THIS MOTOR DOES INCLUDE THE STARTER & ALTERNATOR
I do have access to another oil-cooler for it, but it does not come with one... Plus there is one on Ebay, I was going to use an aftermarket oil-cooler with a fan and larger cooling areas on it.
I am starting a RIGID CHOPPER PROJECT & NEED THIS TO GO TO GET MY 250 wide tire RIGID FRAME....
Got a set of 36 mm & 38 mm mikuni's available
& have available to me here 36 & 38 mm flatslides
Talk at you guys and gals soon.
Happy Holidays!!!!
JDB1371
Thanks muchly!!!!!!
Todd
Edit: Yes, that looks to be a sweet deal..of course it happens to be be on the OTHER coast..*sigh*
[ 12-27-2002, 12:09 PM: Message edited by: toddinNH ]
Discussion Starter · #9 ·
UPDATE - 12-27-2002 - 4:17 P.M. EST
FELLAS,
THIS MOTOR DOES INCLUDE THE MAIN BEARINGS AND ROD BEARINGS, BOTH THE STOCK SIZES CALLED FOR AND THEN ONE SIZE TIGHTER (THICKER) AND ONE SIZE LOOSER (THINNER)FOR ALL, CORRECT ALL THE BEARINGS CALLED FOR. (CRANK AND RODS)
SO, builders, you will have EXTRA BEARINGS FOR THE CRANK AND RODS FOR MOTORS IN THE FUTURE...
THANKS,
JDB1371
Discussion Starter · #11 ·
Rimmer:
JUST 4 u Buddy.
As of 12-30-2002 10:10 am (EST)
This is how it break down:
850.00 USD = 1,339.80 CAD
United States Dollars Canada Dollars
1 USD = 1.57624 CAD 1 CAD = 0.634421 USD
Let me know if your are interested
JDB1371
Discussion Starter · #13 ·
Rimmer:
Do not want to split the motor, but you can find these out there from reliable sources. I do have a reliable source a little farther south from me if you do not come up with one. I would 1st contact Dwayne at Cycle Concepts, who is on here all the time, and I am sure he can help you with a tranny or getting yours back-cut.
Good Luck and let me know if you need me to contact my source south of here.
JDB1371
Thanks JD but I actually broke down and decided to spend the $500 and get a new 5th and 2nd gear and the shift fork and the shift drum .. either way I needed the fork and the drum for sure there is accessive wear on them
Discussion Starter · #15 ·
Rimmer,
Wish you would have talked to me, I SOLD A 88 GSXR 750 MOTOR for 600.00 and a 91-92 motor last week for 700.00 complete... You could have atleast got an extra motor out of it.
AND I Delivered it to Daytona, this past weekend.
JDB1371
1 - 15 of 15 Posts
