Exactly:cheerskaysixsevenfifty said:an aluminum slider absorbs less impact than a delrin slider. that means that instead of absorbing the impact it instead transfers it to the frame and block.
I have the motovation no-cut sliders I had the unpleasant opportunity to test em out a few weeks ago they worked like a champ not a scratch on the plastics or any frame damage.:cheersBrianinms said:Those are valid points, but when the delrin is grinding down and or absorbing force its going to grind your plastics as well as everything else. Do to the length and mounting of the rail it will distribute the force across the frame and you shouldnt have frame damage. Seeing that 25 people or so bought them during the group buy I am sure we wont have to wait long for some results.
I can't even pop a wheelie. But since I have the railz installed, I guess its: "STUNTER'S RULE AND THOSE WITH SLIDERS DROOL"...LOL:lolBlakester said:If you want your bike to look like a "stunter" than throw those railz on there. As for me I will stick with my shoguns...![]()
:cheers Hey Corey!MotoMummy said:they also catch and flip the bike vs delrin that rubs off and is made to grind down as it takes abuse...or even snap off it something hits is VERY hard. something hits metal hard enough it's going to pull on the frame, or send all the force to the frame...etc
I hope you can see how this statement makes absolutely not a bit of fucking sense man :wtfBrianinms said:Those are valid points, but when the delrin is grinding down and or absorbing force its going to grind your plastics as well as everything else. .
Grandevil said:I hope you can see how this statement makes absolutely not a bit of fucking sense man :wtf
Now the rails seem like a good idea...an improvement to them would be a removable delrin outer rail or something. But as for JUST frame sliders...delrin.
Okay...KNEE PUCKS...they're made to grind down...that's the idea, same with frame sliders.
