341 - 352 of 352 Posts
Does anyone know what year model is interchangeable with a 2003 gsxr 1000.? I'm looking to buy an after market throttle tube kit so I can get my throttle cables out from under the clip on so it stops hitting the air intake everytime I take a right turn. It is destroying throttle cables and causing unwanted clutch dumps when it revs lmao
Hello guys, does anybody know if the k4 k5 600/750 transmission will fit a k2 600 ?
Having some issues with the gearbox, so thinking of swapping on a newer tranny. Do you have any info/thread?
Thanks!
hello, I have been looking to see if anyone has posted or asked about my question or not before I made a reply. I am currently in need of both left and right Ram air intake ducts for my 2006 gsxr 600 and I can't find out if my friends 2008-2009 ducts will work with my 2006 model. apparently the 2007-2007 models are more expensive as well for some reason. hope someone who actually know the answer can tell me. I have looked it up everywhere. can't find a definitive answer though. thanks guys.
I've been searching for some replacement parts for my bike, and to find info on some of my upgrades. Thought I'd compile a list of some of the things I have found out, to help others searching. Please correct anything wrong in my list or add other things. Maybe we could make a sticky?
In general:
00-03 750 is all the same. (some electronics are different)
01-03 600
01-02 1000.
750 and 1000 clipons are compatable.
Windscreen / rear seat:
00-03 750's
01-03 600's
01-02 1000's are all interchangeable
Fairings:
all fairing stays are compatable from same gen.
gsxr 600 and 750 are interchangeable from 2001-2003
gsxr 1000 from 2001-2002
PS: The side fairings from a 1000 are not really interchangable with other models.. everything else is.
Front fender:
01-03 600, 00-03 750, 01-02 1000 are the same fender.
04-05 600/750, 03-04 1000 are the same fender but won't fit the above models without modifying the rear fender mounts.
06-07 600/750, 05-08 1000 are the same fender and will bolt straight up to the list directly above (the previous generation) and will need the modification as above to fit the first gen K series.
[/LIST]
Wheels:
600 01-05 - 17x5.5
750 00-05 - 17x5.5 / 17x6.0
all interchange
Rear wheel:
1000 01-04 - 17x6.0 should also fit a 00-03 750
SRAD rear wheel - 17x5.5 (needs sprocket, sprocket carrier and all the wheel spacers too.)
05 GSXR1000, 06 600/750 and onwards rims are lighter with thinner spokes.
Rear shock interchange ability:
600 2001-2003
750 2000-2003
1000 2001-2004 (a little bit higher?)
600/750 04/05 (7mm higher)
Exhaust:
Bolt on:
2001-2003 600
2000-2003 750
2001-2004 1000
04-05 gsxr 600-750
Are all the exact same 4 bolt pattern.
Headers:
01-06 1000 headers will fit.
you have to buy the same year pipe as you do headers.
05-06 headers are the most popular bc of the m4 gp slip on.
Rear rotors:
01-08 have the SAME REAR ROTORS
Engine:
In the 750 the 1000 motor will bolt right up with the exception of the top right front motor mount. They do sell brackets that allow you a bolton or you can have a fab shop make some for you. You will need to buy a 1000 motor kit (harness, cdi, speedo, throttle body, radiator, oil cooler etc)
Swingarm:
2000-03 750
2001-02 1000
2001-02 600
These are interchangeable, but som
96-99, 00-03, 04-05 have the same in the front pivot section, but the length is different (but not much).
03 1000 on my 600 and it fit perfect, but need the rear caliper and mount...
Tail:
04-05 will fit with modifications.
Front forks:
00-03 750 forks and brakes. its cheapest, easiest and the better setup.
04 +750/600 or 05 + 1000 Better, more expensive.
i’m looking at getting a 04-05 750 subframe for my 2003 gsxr 1000 can anyone confirm that it’d fit it looks to be exactly the same i just not much you can do bout eye balling over the internet would perfer to go spend the money if it’s wrong
Anyone know if a 750 rear seat cowl for 2001-2003 will fit my 00 x model. They look pretty much the same but earlier in this thread fairing refer specifically to 2001-2003
They are the same. All parts from the year 2000 (Y) model GSXR750 are interchangeable with the K1-K3 750 models (although there were some updates to some parts in those later models).
In general:
01-03 600
01-02 1000.
00-03 750's
01-03 600's
Fairings:
Front fender:
[/LIST]
Wheels:
600 01-05 - 17x5.5
all interchange
Rear wheel:
600 2001-2003
750 2000-2003
Exhaust:
Bolt on:
2001-2003 600
2000-2003 750
2001-2004 1000
04-05 gsxr 600-750
Headers:
Rear rotors:
Engine:
Swingarm:
2000-03 750
2001-02 1000
2001-02 600
Tail:
Front forks:
Can I use an 01 750 fuel assembly in a 600?
curious if anyone knows which subframes will fit the 03, i want a 08 but i found a steel 04/05 one i’m curious if it’ll work out ?
