1 - 2 of 2 Posts
I am getting ready to install my Micron high mount this weekend. Anything special I need to do. I think Ive read about error codes coming up with some people. Any input would help. Thanks
Once you remove the SET valve it'll throw Fi code, you need to unplug the brown/black wire from the harness that is located underneath your seat (if you're siiting on the bike it's the harness on the left)
I believe it's the 8th wire from the left on the bottom row. Other than that it should be a pretty simple install.
1 - 2 of 2 Posts
