I recently bought a 2006 gxsr 600 which had a small fire at fuel rail to fix. It has a new wiring harness and the fire burnt all wires for sensors around motor (tps, injectors, speed sensor, gear shift sensor, crank sensor, coolant temp sensor) I’ve replaced all sensors and injectors replaced all fuel lines and got it right. Now the F1 codes it’s throwing are for all sensors I just replaced. I don’t have fire to my injectors. With a test light the injectors kick on when switch first turns on. Then losses power. At the fuel pump relay if you ground the yellow/black wire to the frame it picks up voltage to injectors but still will not crank and green wire doesn’t pulsate when cranking the bike. Shook the tip over sensor and double checked all wiring and can’t get nothing. Help!
