1 - 2 of 2 Posts
Hi all! I am wiring up a gsxr 1000 motor on a dune buggy and I'm not getting any fuel from the injectors. I have spark and the fuel pump is priming properly. The motor will run on starting fluid. Are there any safety sensors that might cut fuel? Maybe the tip over sensor?
Tip over sensor for sure. I'm a little surprised that it would even prime if the tip over was tripped. Are you sure that the camshaft and crankshaft position sensors are working? It sounds like you don't have a cluster to read the error codes. You're running blind without it or an equivalent.
1 - 2 of 2 Posts
