have an 88 750 frame/body with an oil cooled 1100 motor. has a dynajet 2000 kit. im getting power to both coils, but the 2-3 coil isnt getting signal from the trigger. how can i troubleshoot the trigger/harness? the coil fires fine when the power wires from the 1-4 coils are put on top, so its definitely something with the trigger signal. are the triggers different from stock for the dynajet kit? ( i didnt install anything, got the bike like it is) thanks for any help.
use a multi meter and test the resistance on the orange wires going to them from the black box. should be like 4. ohms of resistance. or less. if so.
check the two wires coming from the pick up coil on the right side cover in front of the clutch cover.
it should read like 150-180 ohms here if not its bad.
The dyna 2k has its own signal generator. And the stock one will not work with it. Be sure when you get one, too get one for the right motor. Is yours the 1052(86-88) or the 1127(89-92). BTW welcome to the board.
