On my 91 750 Iam getting spark and it sounds like it wants to start. From left to right the coils read 1-2-3-4.Is that the firing order. Because who know the numbers in the wires could be wrong.The way there positon straight from the coil is 1-4 & 2-3. Here another funning thing.. when I pull plug number 4 out it really sound like it wants to start. when I put it back on it doesnt sound like it wants to start. Any sugg.
Thanks
[ 04-27-2002, 08:39 AM: Message edited by: Dontilgon ]
One coil fires cylinders #1 and #4 and the other fires #2 and #3. Check to see that you have the low-voltage leads from the CDI connected to the correct coil. Firing order is 1243, but you can swap #1 and #4 or #2 and #3 because the coil fires the pair of cyls, not individually. The only way you can goof on the coils is to connect the #2 and #3 coil to the #1 and #4 cyls or vice-versa.
um... it's kinda difficult to describe in words... each coil has two wires connected to it from the wiring harness (these wires are from the CDI) as well as the two spark-plug leads. It really doesn't matter so much what order everything is laid out in ...aww shoot, a picture is worth a thousand words, right?
and here's a diagram of actual wire-routing...
I hope this makes sense.
