1 - 2 of 2 Posts
Hi, thanks for checking out my post.
my k6 gsxr750 has been acting a bit strange again.
At idle/low rpm’s it seems to only fire on 3 pistons, and once I get higher (depending in what gear I’m in, usually around 7k) the fourth one kicks in, and the bike rides normally. This generally happens every time I stop but sometimes it kicks in earlier, sometimes later.
I checked resistances for the coils and everything seems to be ok. The one issue with them that might be contributing to the problem is that some of the rubbers that seal the stick coils in are warped.
I’m thinking of checking the spark plugs next.
Anyone dealt with this issue before?
Any advice?
thanks as always 🙏
Ride safe
I would’ve pulled the spark plugs when you had the tank up to check coils.
I bought a 07 gsxr 1000 last year for 4K cause the guy thought it had engine trouble, ended up being a bad spark plug on cylinder four.
Fixed the problem and sold the bike for 7k to buy a 2017 1000r.
Sometimes it’s just the simple things that cause issues.
1 - 2 of 2 Posts
