My 2009 GSXR 600 got dropped on its left side now it wont start. I put it into dealer mode (paperclip method) and i got the C00 code which means nothing is wrong. I also get a flashing FI light. I have tried everything online. Also something interesting, i took out the tip over sensor out of its rubber housing and turned it to its side then ran the codes to see if the TOS sensor code would pop up, it didn't even though the TOS was turned to its side. anything helps thanks.
That was five months ago. He probably found the problem by now. He might have had other problems.
The flashing light indicates a major fault so severe that it won't start. There ought to be associated error codes but turning the ignition off to fiddle with the dealer mode connector will clear most codes. As long as you're sure that there's no overheating problem, it's simplest to put it in dealer mode an leave it there. A real dealer mode switch is recommended. I've experimented with routing the TOS cable on my K6 so the TOS sat outside of the bike's left side. With the bike running, tilting the TOS to 45° or so would cause it to suddenly stop and produce a C23 code. The C23 was unexpected as the service manual led me to believe that it only was produced by a faulty sensor. I'd expect his to behave the same. I don't remember this but the service manual indicates that a tip-over condition will cause the red fault indicator to go into the flashing/no start mode. It's not enough to correct the tilt. The ignition must be turned off and back on.
