1 - 2 of 2 Posts
i dont' have a fsm, but i'm picking up a clymer's tomorrow. i was just wondering how to remove the throttle cable from the carbuerators. i have everything else off, but that. thanks in advance.
rock on
-wil
Wil, you'll see when you get the carbs off that in the center, between the 2 & 3 carbs there is a sprung-rotating holder where the barrel-end of the throttle cable is held. If you rotate that holder with your thumb and slide the barrel of the cable out to the side it will be free. There may be a barrel adjuster at the top of the cabs that the cable passes through. I should take a 10mm wrench to loosen it and then undo it all the way and the entire cable will be free of the carbs.
1 - 2 of 2 Posts
