I cant get it loose for the life of me, there isnt a way for me to hold it to remove it. Anyone got any tips to remove the front sprocket off the engine?
YAAFM Mod
you need to remove the small bolt in the center, than bend out the tab, then put a impact gun on it and while you impact it off use a strap wrench or rag hold the gear. Do not have the tranny in gear while doing this as it will damage the gears.
Bones
I put the bike into 1st then hold the rear brake pedal down, assuming the bike is in one piece after a bit of elbow grease it will undo!!
Good luck.
