I know this is kinda stupid question, but I bought the coils used and didn't get a instruction sheet. The coils are set up a little different. The connections are front to back rather than side to side like stock is. So the question is what wires get connected where. The top of the dyna coils have no markings.
Dyna
Dyna
Stock
How do I know which spark plug wire goes to which piston? I'm sure this is fairly simple but I am currently brain dead.
Thanks.
one coil fires cylinders 1 and 4, the other coil fires cylinders 2 and 3. it doesn't matter which plug wire on any particular coil is hooked up to which cylinder, as long as it's one of the ones that that coil's supposed to fire. it doesn't matter to the coil; it fires both simultaneously.
So 1 and 4 fire at the same time and 2 and 3 fire at the same time. But the individual wire that connect to the top of the coil don't matter either, just as long as they are going to the correct coil?
