1 - 17 of 17 Posts
How much HP my \'02 600 w/ exhaust puttin\' out???
How much horsepower is my '02 600 putting out to the rear wheel? I have a D&D slip-on exhaust on it. Also, what are the 0-60 mph & 0-90mph times and top speed?? That's all I have done to the bike...
Just wondering--too lazy too look up.
Re: How much HP my \'02 600 w/ exhaust puttin\' out???
Sorry--too lazy to help out.
Hey thanks alot smartass...
Anyone else?
OK, found out what the HP is (115)
Now, just looking for the 0-60 & 0-90 times and the top speed...
115 at the crank maybe, probably around 99-102 at the rear wheel.
0-60 is around 2.8
0-60 is around 2.8
I agree. My old '03 600 was putting out 112 at the rear wheel with a full Yosh and a PCIII with custom map.
113hp out of a 03 600.....thats pretty optimistic on pump gas even with a PC and pipe. Maybe with VP or Nutec but not pump gas.
01-03's barely made 100hp the majority of the time on an accurate dyno. Typical gain of 5hp with a full system of you pick with PC. 105-107 being the norm range with 110 being a freak high output.
People and the dang dyno numbers they claim........worst than some of the magazines i tell ya.
Your max speed is the in the 155mph range.
on an accurate corrected dyno the 01-3 should be at 97-100 rwhp. with a slip on im guessing 103 because its proally broken in a lil too.
It dyno'd stock on BP Gold Pump at 103 and was at 112 when they finished it. Unfortunately, when I sold it I gave the new owner all the paperwork that went with it, or I would be happy to post the dyno sheet for you. But I don't, so I don't have a shred of proof for you anymore.
also depends on wat kind of dyno u use, not sure exatly what its called but theyre are 2 kinds of dynos, mine pushed 99 rwhp on the more "accurate" type of dyno
The numbers aren't off, and the bikes aren't off........the dyno's are off.
A factory eddy dyno is the "true rear wheel hp" type of dyno. And will put these GSXR's at about 990-95 rwhp.
A dynojet dyno (most common) will put these bikes at 95-100 rwhp.
A slip on will do virtually nothing, at most 1hp on top end. A PC alone will make more hp than a slip-on.
Next time you guys go to a Dyno ask to see some files from other bikes that ran before and after mods. I know a dyno owner personally and spend a lot of time with him and his machine.
Again regardless of how "high" your numbers are its the improved number you want. And I will tell you no full exhaust and PC is going to give you 12+ hp and likely not even 10 hp gain.
Discussion Starter · #13 ·
Thanks everyone!
Discussion Starter · #14 ·
How 'bout 0-90 mph??? Anyone???
My 03' 600 made 97.8 out of the box...Full Hindle system and map made 105.8...Just pulled my 05' 636 and was very happy...112.8 with a little under 1000 miles...These were all done on a Dayton Dyno.
Now those sound like accurate numbers!!!
Just to compare 02 600, PCIII, Akro bolt on.....
96 hp with a zero map.... After tuning 101.....
1 - 17 of 17 Posts
