I want to pull my sets off and clean them up...onadized alot...does the trans rod just pop off or is there a trick....looks to be ball and socket but I want to be sure...I dont know the proper terms but its the rod that you use to change gear...goes from the foot peg to the engine...
It should just unbolt from the rod passing into the tranny and the point where it mounts to your rearset. You can take them apart as far as the "ball" staying in the "joint".
Super Moderator
10mm bolt on the gear shift rod down by the front sprocket cover..Take it off and the whole rod connected to the rear set will come off..
