1 - 2 of 2 Posts
Re: How do you adjust the engine rpm indicator for the GSXR6
are you talking about the shift light? cause if you are, just hold down the button next to the shift light, then turn the key to the on position (don't start it). after a second or two, it should go all the way up, then drop down to 7,500, then you just keep hitting the button, and it will increase by 500 increments. then hold down the button when you are done. that simple.
1 - 2 of 2 Posts
