I just found out that a previous owner installed later model gixxer carbs on my '86 750. How do I figure out what size they are, or which model they came from?
should be a code on the left outer carb somthinng like 18d3(38mm)or 17c30 17d30(36mm) will be quite faint and hard to read,or you can just measure the inner diameter with a set of vernier calipers.put up the code and someone here will know
