1 - 2 of 2 Posts
I got the jet kit for 89-93 katana 1100carbs 3323.002
Anyway the instructions say drill the slide lift (hole).
We have two on these carbs, I assume you drill both the slide lift hole(s) right.
Also what does this do. Change the vacume? for the CV's to work differently?
Thanks
GregW
the instructions aren't clear on whether to drill one hole or both on the slides.....the holes control slide lift speed.
if you drill both holes (basically you're just making the existing ones larger), the slides will open quicker than if you drill just one, or don't drill them at all. when the slides open quicker, you get better throttle response, but if they open too quickly, the bike will bog if you open the throttle too quickly at lower rpm's.
i'd call them and ask them to clarify....the problem with just simply drilling both holes (when only one is required) is that you can't easily undo it....
1 - 2 of 2 Posts
