Hello!
I have a 92' GSXR 750. When the bikes warms up, it starts to get really high revs when I pull the clutch in. But in gear it revs pretty normal. I'm not sure If my idle is too high or what. But it only happens after it gets warm. Any thoughts? Thank you!
You have a vacuum leak where the carbs install into the manifolds, or where the manifolds seal onto the head. Also, you may need to synchronize your carbs. Also check your clutch cable and make sure you have enough play.
Thanks! Ill take a look at that tomorrow!
there is a grey colored liquid gasket product, 'Yamabond 4' or in the auto parts stores it is a "Fuel impervious" grey product, works wonders on gasket leaks. We used it with great satisfaction on the old oil cooled 1340 methanol monsters Formula USA bikes. Once you clear any vacuum leaks, reset your idle fuel screws, check your float heights, and synchronize, then set your idle speed.
