1 - 12 of 12 Posts
So here’s my baby I got her maybe 5 years back for 2k in boxes so I put it back together as a 1201cc 1127 stock head with just springs everything else stock besides Bolt on goodies MTC clutch Dyna 2000 ignition with two step high and low limit dyna coil’s onboard air shifter bike went 9:89 with 155 pounder on her back and I pounded this thing for years until I got a rod knock on Christmas day 😐 berrrrppp haha so like I told you the bike came in lots of boxes with lots of parts well in one of the boxes was a full Mr. turbo race kit So my gear started turning and I got obsessed with it I slap together a “on junkyard engine so my gear started turning and I got obsessed with it I slap together a quote on quote junkyard engine used 18,000 mile stock 1127 Pistons and cylinder (ebay) stock head basically a bone stock engine with goodies as in 2 mm cometic cylinder spacer cometic copper base an head gasket APE adjustable cam gears ape studs and head bolts mr. turbo kit Holly performance Blue pump (Electric) 5 psi fuel pressure with a Y fitting that I ran up to a handlebar gauge didn’t want to starve it out at all LOL nobody does I had a AFR bung put into my downpipe with AEM gauge in a pod up too I also ran a HSR-42 which I know a lot of people aren’t big fans of but once I understood how that carburetor worked in like four sections man that was nice mind you I’m 26 years old an had no clue about this old turbo system it really took blood sweat and tears lots of tears 😂😂😂 I had to prove all my buddies my age that these 1100s Were no joke I did this all myself and a little one car garage built jetted tweeked tuned myself so after about three months with this build you could only imagine I was one happy SOB when I was done and smashing their busas pride I had the Dyna 2000 with -8 degrees off the 35* stock I was running 15 psi on c10 an running the city late nights open down pipe mre airshifter with the kill box you should’ve heard that thing pop and bang and Spull back tire just screaming like it was getting ripped in half I love that 1100 lol there’s my little story guys 😂❤🤘👋💥💥💨💨🏍🏍🏍💭💭💭💭🙃🙃🙃
Three things:
1) I'm digging the XN85 turbo placement. Even in the 80s, that was unique.
2) Punctuation is your friend. A mountain of unformatted text is a pain to read
3) Did I read correctly, that you're running 15 lbs of boost on stock internals?
Three things:
Yes it was perhaps a ticking time bomb but I am a big believer in living and learning and doing it yourself because you can read anything on the Internet I was throwing a ton of fuel at it maybe 230 to 250 main jet an I believe 40 pilot jet timing pulled as well an the cylinder spacer to drop compression which helps a lot this engine lasted 2000 miles of brutal tapping off the box ringing its brains out every other stop sign I didn’t have no issues with temperature I also added I believe a 6 x 6“ electric fan to the oil cooler and as well some nights I really had that spring turned up 😂😂🤘🧙‍♂️🧙‍♂️🧙‍♂️🧙‍♂️
Discussion Starter #6
Yes it was perhaps a ticking time bomb but I am a big believer in living and learning and doing it yourself because you can read anything on the Internet I was throwing a ton of fuel at it maybe 230 to 250 main jet an I believe 40 pilot jet timing pulled as well an the cylinder spacer to drop compression which helps a lot this engine lasted 2000 miles of brutal tapping off the box ringing its brains out every other stop sign I didn’t have no issues with temperature I also added I believe a 6 x 6“ electric fan to the oil cooler and as well some nights I really had that spring turned up 😂😂🤘🧙‍♂️🧙‍♂️🧙‍♂️🧙‍♂️ View attachment 570666
That first picture of the bike launching looks a little 'vintage'. Given your reported age and apparent enthusiasm, I'm surprised I have to ask but can you post a video of the bike running / being ridden, the way she sits today?
I also have an 80s turbo bike but I've only posted video of it starting and idling to warm-up.
Discussion Starter #11
How do I post a video they don’t work even at only 15 seconds that’s 5 years ago at Cecil county raceway Maryland pa I was 21 it was on my birthday matter of face lol rolled in like a boss with suzuki loaded in the bed of my ranger hehe
1 - 12 of 12 Posts
